qquake
I would like to stain a light colored wood blank bright red. But the only red commercial stains I see are dark, almost a brick red. Are there any alternatives to commercial wood stain?
			 www.leevalley.com
					www.leevalley.com
				I have used powdered rit dyes with DNA as the carrier. But again these type dyes as with all dyes will not penetrate deep. You are best to turn the desired shape first and then dye using any type dye. The alcohol and oil based dyes work best as opposed to waterbased. Plus they will not raise the grain much. Just my opinion and again Trans Tint dyes are very intense wood dyes. I have used them to color epoxy too.I guess I should have given more information. My sister is a freak about red. I have made her red acrylic pens before, but wanted to make her a red wood pen. I have turned red heart before, but it's not red enough. The effect I'm looking for is wood grain but bright red. What about liquid Rit dye? Maybe I'll turn and sand a couple of test pieces between centers and experiment with them.
I've used this method on a knife for a lady who wanted a pink handle. Turned out well but, as noted below, it's the final step before your final finish.Regular artist oil paint can also be diluted with DNA and you can virtually make any color stain you desire. It works very well.
Experimenting is good. I will warn you that all woods take stain differently. Burls will not stain evenly. Also the higher grit sandpaper you use will close the grain and no allow as much stain to penetrate. Also end grain will absorb more stain than flat grainI was planning on turning and sanding it before I apply the stain or dye. I have DNA, I might experiment with powdered Rit.
