I wanted to try a little inlaying using mica powder. I'm engraving with my Neje 3500 master. Normally the wood is engraved at a 30 power. I engraved this wood at 45 power and wasn't deep enough. So I burned it at 45 power twice. That gave me a pretty good depth to work with. So I filled in with mica powder and then took thin CA to harden it. That worked good also but the CA seemed to soak into the wood and am unable to sand it out without getting into the pattern. I was wondering if there might be a different bond that I can use that won't soak into the wood and easily sanded off? Or maybe I can coat the wood with something before I do the mica powder that will keep the CA from soaking in. Looking for some advice to anyone that have used this before. Thanks! Below is my first test.
