I know this has been done. . .
MDWine
Manassas Park, Virginia, USA.
. . . and I've seen the thread, but for the life of me I cannot find it now.
I want to take my acrylic/plastic/resin/etc cutoffs and get them to smaller pieces, then cast them into blanks.
Not technically difficult, but I wonder the best way to make my cutoffs smaller?
I want the individual pieces in the 1/8" range... kinda small compared to what I have seen before.
I'm thinking start with a hammer, and maybe that's all I need?
What about an electric mixer kind of machine? Maybe that would make things too small and/or dusty?
So I am polling the IAP collective for thoughts and ideas on the topic...
(the IAP BORG... all your blanks am belong to us) lol
Not done it myself, but some have used the hammer method to break the cut offs into smaller pieces and then place them into a mold with a single color resin. I've seen it done with a white resin. I suppose you could do it with any other color you want. If you have a fine tooth chop saw you could cut the cut offs into small slices and then snap them off with pliers to get smaller irregular pieces. I will wait to see what others may offer as I have lots of cut offs sitting in boxes with no place to go.
Turncrazy43
If you are particular about chunk size you might want to use a screen to sift the particles then put the leftovers back through the crushing process till you get what you want. A somewhat finer screen can separate the dust from the desired size too.
Michael, you can use an iron pipe cap as a mortar and a hammer as the pestle and smash those cutoffs.
re the blender idea I suppose it depends on how fast you can run when the wife spots you ! 😉
Should work but for consistent sizes you might want a garden sieve to run stuff through. i wou"do use a bandsaw and accept the losses from the blade curf. Hold the pieces in a wooden clothes peg NOT your finger though and have the hpguard set really close to the pieces. If you cut a piece of hard cardboard and tape it in place half cut it will stop the segments getting drawn i to the blade orifice.
I put a blank in a plastic bag then busted it up with a 5lb sledge. After casting the pieces in white resin this is how it turned out. I think a blender would give similar results depend on how long you ground it up for.
Thanks everyone for your responses. I just may have to look for a used blender on the yard sale sites and give this a "whirl"... lol
This will be a winter project, I gotta turn some 'birdie houses' for Christmas!
THANKS!!
I've frozen thin pours of resin to make them more brittle, and then pounded with a hammer. This was Alumilite, which does not break quite as easily as PR.
