360 herringbone using mesquite
See more from its_virgil
its_virgil
Wichita Falls, TX, USA.
72 tiles to make 12 6-tile layers to get a blank to make this sierra. Of course, the number of tiles is a function of the tile thickness. Enjoy.
Do a good turn daily!
Don
Nice work Don. I've always admired those that get these correct. I didn't think anyone was brave enough to still be doing them these days...😀
Great looking pen, Don !!! . And I appreciate the photo of the "pre-turned stage".
It would also be useful to me to see a photo of a single "tile" if you have one, please. . I have forgotten how these go together. . I suppose there might be one in the "resources" somewhere.
Thank you!
I've written two articles: one on the herringbone blank and one on the herringbone 360. Both are here: https://drive.google.com/drive/folders/15IW-0xsjdualYFMUYVcF6r50aHUnmcwg
Read the herringbone article first just for some continuity.
Don
Thanks very much, Don !! . I have downloaded your pdf's and will study your processes.
I am now wondering about the optimal dimensions for the individual squares. . And also about alternating colors in some ways.
Excellent work, and a great article Don. You explained the assembly very well and there are a couple of good tips in there that I think i may employ in my next set of blanks.
I like your method of wrapping the strips together, but I prefer the orientation of the other pieces. I prefer not to have any endgrain visible. I think your method could also work if you cut the strip off the end of a board, then wrap them together and cut them. They are a lot more fragile this way, but I prefer the look.
Thanks. The first one I did I used Scrabble tiles purchased from Hobby Lobby but their thickness was inconsistent and they were not square. The next one I made from slices cut from pen blanks but that took lots of cuts to get the needed number of tiles. Cutting them the way I did but from pieces cut from a board the way you suggested would work fine and I will do that next time. I like the "no end grain" tiles. And, contrasting woods could be used.
Don
You're welcome and I hope the articles work for you. Optimal dimenmsions: .75" square seems to work well and I made the last two thinner than the first. I will go a bit thinner next time. Thinner means more tiles.
Do a good turn daioy!
Don
Yes, thinner means more tiles. . It may also mean a slight change in the aesthetics ... don't know until after a trial.
I am thinking that a smaller tile, say 0.5", would reduce the amount of wood that gets turned off. . But I don't yet have a feel for any possible negative implications of making the tiles smaller by this much.
Thinner tiles will add to the number of tiles. My first herringbone FP uses 3/32" tiles. The body here is made of 20 rows, or 120 tiles.
The way the blank goes together, there is inherently a lot of loss. If you use smaller tiles, when you cut away the protruding points, you will be left with a smaller core. Depending on the size you need, this could become a problem. The smaller the tiles, the harder they will be to work with as well. I can tell you from experience, that even the 3/4" tiles are fidely.
Darrin,
Thanks for joining in the conversation. You certainly have more knowledge of these blanks than I. Thanks for your article in the library that was the inspiration and the instruction for me making my first three of these blanks. I think my next will be thinner to compare with what I have already made. Larger pens will require larger tiles and yes, cutting off the corners reduces the size of the core for making a pen.
The pen you showed looks really nice.
Thanks again,
Don
Thanks guys. The pen i showed was my entrance into the Pen Artisan Guild. It is a natural finish, due for a polishing real soon, and has been my every day carry (EDC) for the past 3 years.
