Blue and White Kitless Fountain Pen
See more from Ironwood
Ironwood
Mackay. Australia
The next one off the lathe in my kit less journey.
This one in blue and white acrylic resins.
Homemade stainless steel clip.
Very nice, Brad - great job getting a uniform satin finish on the barrel.
What type of stainless did you use? It comes in so many different alloys and variants of hardness!
Thanks Duncan.
It all has a gloss finish, my diffused lighting does a good job of making it look like a matte finish.
The stainless I use comes from old hose clamps, the thicker stuff I used on this one came from a clamp over 2 feet in diameter, I save a couple from going into the rubbish bin at work now and then. So I don't know what grade it is, but it's the right price so that's why I use it.
I like your work, Brad !! . :)
I will have to try making a clip the way you do from a large size hose clamp band.
Cheers Mal.
I use a angle grinder with a 1mm cutoff disc to do the cutting out, a smooth file and sandpaper to refine the shape.
The stainless is not the easiest stuff to work with, but it's tough and holds its shape, and it's cheap.
