John Eldeen
So as you can imagine from the title I am in the market for a resaw blade for my band saw. It can take a 3/4 inch blade so I am thinking the is the size I will go with. I will be cutting mostly 3 inch and down materials ,mostly hard and figured wood. I currently use a timberwolf 3/8 3as blade for everything. But I have some plans for projects that I will need to cut a bunch of veneer for and the cut with my current blade is just not good enough. This finally leads me to the question that I could use some help with. The tooth count and set. Less teeth like a 2/3 vpc should get the job done but, in my reading more teeth like 14rk will produce a better cut but the feed rate will be slow? Maybe the answer is somewhere in the middle? My only concern is the cut quality. Any advice would be greatly appreciated.
