Cebloplast
See more from Cwalker935
Cwalker935
Richmond, Va
I bought a slab of vintage cebloplast from SteveG a while back and finally make a couple of pens from it. It polishes up very nicely. One was my entry in the Pretty Resin contest.
Very nice! I love the final appearance of cebloplast but it's not always fun to work with. Found it to be easy to melt it it gets hot while turning. Definitely worth the troubles.
Definitely have to drill very slowly, even with that I had to clear the bit often.
This post makes me wish I had more of that material. Nice work! When I was in the process of moving from Kauai to Eugene OR, I was burglarized, and lost a large amount of vintage and special pen materials. :eek::eek: I had most of my shop stuff in boxes ready to load for shipping. The next day much of it had disappeared. The sad thing is that the thief probably had no idea of the value. He may have tossed it after making off with my stuff, and later evaluating the proceeds of his nasty deed.
Hard to replace!:mad:
I would spray some Pam on the drill bit, and into the hole being drilled. That was after having a blank of Ceblo literally melt onto the drill bit. I had to break the locked-on blank off the bit. Obviously not a good pen making day. :frown:
Gosh, Steve ... sorry to hear about your loss ... such a horrible thing to happen at that time !
Cody,
What kit is the upper pen, please ? . It seems to have a very substantial clip ... I just noticed the clip and I find it very attractive.
I too love working with this material. They make some nice pens. I too wish more of it was available. There are some cool colors out there. Never really had a heat problem with drilling or turning but again I do things a little slower. Just never in a rush. Thanks for showing.
Glorious Pens Cody,
Amazing Cebloplast Blanks, Stunning Colours,
Beautifully Turned, Fitted and Finished.
Love your Choice of Hardware, I have not seen Curvado Twist Pen before, and with the Knights Armour, Both look Terrific with this Spectacular Blank.
Thank you for Posting,
Splendid Pens Cody.
With your indulgence, I would like to deviate slightly, and empathize with Steve, with his Anguish and Anger, of having lost such Fantastic Material to Some Opportunistic Grub.
There are no words that could cover the emotional impact of such a deed.
I am confident that I am expressing the Thoughts and Feelings of many of our Members, to Steve.
Brian.
I'd have to disagree with the use of Pam on anything that moves around such as a lathe. A better substitute, in my opinion and expect, would be a lightweight oil such as 3-in-1.
I've worked in several kitchens in my short life. I had a cook in the last kitchen lubricate a meat slicer with Pam. It worked great for a few minutes and then seized up rock solid. Of course the story I got was "I dunno what happened." I took it to a repair place. A few days later they call and ask stop by. When I get there, they showed me what happened. And of course the bill to remove and clean out all the cooking spray lubricant.
Cebloplast is great stuff to work with. I love it but as mentioned, it's not easy to come by at all.
Mike, perhaps if you understood how I employed the Pam, there may be less objection. I had a piece of firm cardboard that I would lay across the lathe bed to collect any overspray. Never needed to clean up at all, except to wipe down the drill bit, and of course clean out the drilled blank. I never got any overspray on the head nor tailstock. Compared to someone actually using the Pam as a machine lubricant...that is a far different case. :eek::eek: I probably drilled over 100 Ceblo and other heat-sensitive blanks using the Pam, with zero negative effect on my lathe.
Everyone can decide for themselves their preferred method, but this one worked for me, over and over. :smile::smile:
A beautiful material to say the least.
I'll weigh in on the lubrication. I have used the cooking sprays and even better for me is cooking oil applied with a brush or a small spray bottle if you prefer. Soapy water works too as long as you can keep the water off things you don't wan't to rust.
I don't use petroleum based oils or solvents of any kind because they attack plastics as do ammonia cleaners. They make acrylics craze (a lot of surface cracks) and yellow. I won't take the chance of future damage to the rare vintage plastics from using the non vegetable oils on them. You could look to the machining industry for lubricants and coolants specifically for plastics if you don't want to use a soap or vegetable oil.
