When you need to take a break from #6, you can work on #7 for relaxation.
This is a word finder puzzle. There are 30 words hidden in the scrambled letters in the attached pdf file. The target words are all at least 3 letters long.
There is a common theme for all these words. Once you find a few likely words, you should get an idea of the theme. It is possible that there might be some random words in the grid, so if you find a valid English word that does not fit the overall theme, you probably should ignore it and keep looking.
Words might be horizontal, vertical, or diagonal and they might be forward or backward. All words are singular.
Here are the rules:
1. Print the scrambled letters in the attached file and look for the 30 words.
2. Make a numbered list (1-30) of all the words you find and put them in alphabetical order.
3. Send your entry to iap.puzzles@gmail.com and put Puzzle #7 in the Subject field and include your user name in the message
4. Your numbered, alphabetical list may be sent either as a Word, Text, Excel, or pdf attachment or in-line with your email message. I will let you know if I have difficulty opening any attachments.
5. This contest will close at noon CST on Monday, Feb 18.
6. Get all 30 words correct and you will earn 1 point.
Let me know if you have any questions.
As always, banter is encouraged, but please do not post any of the actual words or strong hints.
PLEASE BE SURE TO ALPHABETIZE YOUR LISTS. That will help make it easier for me to check your words against the master list.
Good luck,
Edgar
Here are the rules:
Good luck,
Edgar
