Wanted 60 Degree Drive Center
Timber Ripper
Burlington, NJ
I'm having trouble locating a 60 degree drive center or may also be referred to as a "dead center" like shown in the picture. PSI only carries the spur'd type.
I'm looking to turn between centers.
Grizzly, Little Machine Shop, Shars Tools, eBay, Amazon, Aliexpress, and tons of other places including a machining supplier in your area.
I used Grizzley when I ordered one some years ago.
You can spend several dollars more and get the dead center with a carbide tip vs the solid steel version.
If you are a wood turner, then you probably have the skills and tools to make your own.
The taper can be wood, with a length of rod glued into the end and sharpened into a 60" cone using a file while spinning it on the lathe.
