Highly figured Desert Iron Wood
See more from MikeL
MikeL
Tennessee
The blade is 1095 carbon steel. The dark line is where the steel was differentially heat treated (called a Hamon). Below the line to the cutting edge the steel is harder.
Thanks for looking.
Very impressive and the handle is some exceptionally beautiful ironwood. . Congratulations on your workmanship !!!!!
How did you engrave your name on the blade ? ... laser or ?
Thanks for all the comments.
The makers mark was put in with a process called electro-chemical etching. It uses a stencil, some mild chemicals, and electrical current.
Mike
