Ken Wines
Here are some of the 3D textured pens that I have done in the past. I did the design work on the pen shapes and textures. They all were cut on a CNC router that utilizes a custom built mandrel based rotary axis.
It would really depend on the task at hand as to what might be the best tool to use. I have a wide variety of tools that I use on a regular basis. A 1940 something South Bend Metal lathe is the tool that probably gets the most use in my shop (the Keurig coffee maker comes in a very close second). Also, I might add it is not necessarily the tool, but perhaps the working knowledge of the tool applied by the operator.Hand tools just can not compete with machines like that.![]()
I have given up on the idea of selling these kind of blanks. There's not much left to do after they come off the machine other than the applying the finish, and who really likes to make a pen and do just the finish. I'll make a new design every now and then to break up the routine. Most of the pens I give away in one fashion or another. I did get a couple of custom blank orders last year for 25 blanks each. The requester said he'd like for all of them to look alike and that's what I try to deliver.Hope you sell lots of blanks![]()
The laser inlays and puzzle pens are a little different. I sell them as kits with the inlays pressed in place and the puzzle are worked around the tube. They still need to be glued and the tube centered and glued. This is usually the same operation on most of the inlays. The way I do them I center up the tube and flood the joint lines with thin CA which glues the pieces together and also glues the pieces to the tube. They have 1/8" wood thickness and do requires some turning to get them down to size and shape. You are very correct that blanks sales are much more profitable than finished pen sales. I sold more blanks in February alone dollar wise than the finished pens I have sold in the last 4 years. The beer barrel blank that you refer to was kind of year end filler when I was try to come up with a new design. I tried to design in detail even down to the rivet heads on the ring. A buddy of mine that makes cast JD Label upper blanks for the Cigar Pen suggested I might get some JD blanks for the lower part and carve the barrel in the lower and pair them up.What are you talking about. you will be offering the puzzle blanks and they are done. there are alot of blank makers that take the work out of making a pen. There is a market for everything today. More money made in blanks than pen turning and that is a proven fact. Seen it here so much. Hope you do well.
That third pen from the left, I will take a swing at that one and do it my way. I will put it on my list to try pens. always up for a challenge. Can not compete with anything scrolled in wood like that but basic lines and circles anyone can do.
