Advice for clock inserts
See more from mark james
mark james
IAP Collection, Curator
Strongsville, Ohio
Three years ago I turned those 3-4" desk clocks for members of my family. All the clock mechanisms are broken and I would like to get better made inserts. These are approximately 2 1/4" D x 3/4" depth.
I have forgotten where I bought the originals; I suspect Woodcrafts or Pat Catans (a local Hobby Lobby). The back reads: HD-1688 Sheng Bang Made in China.
(I'm not interested in critiquing Chinese products, I only include this so that I don't replace it with the same... If possible.)
I am familiar with Klockit's website, but have not ordered from them. Any suggestions for better made inserts? The wood bases are fine (notwithstanding my general turning skills!), so better inserts would be appreciated. (My kids actually like the desk clocks and brought them home for replacement inserts).
I have used Klockkit as a source for several years. General experience is the larger movements seem to last longer (several years). Klockkit uses fewer odd battery sizes.
These are the instructions I used (I had a copy still), but it is in the PSI archives area:
https://www.pennstateind.com/library/FP002_ins.pdf
NOTE: I did not order/use the PSI Inserts, so I had slightly different ID dimensions.
Plans make a nice small desk clock, but the inserts are the weak link.
I believe these are the size I used (mine from a local vendor): https://www.klockit.com/all-departments/clock-inserts.html?inserts_overall_diameter=258
At that price, my memory is beginning to clear as to why I used a cheaper source - I got what I paid for...
Hello Mark
There are many sources for clock inserts. Inserts come in 3 categories good better and best. Is the insert a 2-3/4" insert?? They are the most common size. What size battery is used on it?? What is wrong with the insert? What size hole was drilled?? That will be a determining factor too.
Hello Mark
A 2 1/4" insert.
The inserts do not work... All batteries were updated.
A 1.5 v battery.
Drilled hole was for the 2 1/4" insert = 2 1/4"
I am looking for "Best" inserts.
Well Mark the problem will be the odd size of 2-1/4" but there are makers. They come in Economy, Standard, and Premium. The best inserts are the ones marked premium and have a glass bezel as opposed to a plastic trim ring and plastic lens. They are pricey. One other thing, if you are looking for a brand name Seiko is a good brand name.
Here is a US maker that has a good warrenty so you know the insert is good quality.
Clock Inserts
Another of my sources
Clock Inserts 2 Inch Range Size - 2 Inch Fitups
Never ordered from these people They do carry 2-1/4" inserts. They are standard grade using an "N" cell
Clock Making Supply - Clock Inserts/ Fit-Ups - 2-1/4 & 2-1/2 Clock - WoodworkingParts.com
Mark
Using John terminology, I use Standard and Premium and experience 5+ years of use with about 12 to 15 months on a battery.
Have one from 2001 still ticking. Premium or best movement
I do as Ken does also and I sell lots of clocks and I have never gotten a recall on any. I do not use the size you mentioned very often. Now I also use some real highend inserts that are really pricey but use those on the special projects.
By the way Japan is better than China.
Marquis By Waterford Clock Face Insert, Large Round
I order from these people alot also because I use these inserts alot
http://www.megaquartz.co.uk/contents/media/l_45mm facet.jpg
Clock Insert Movements, Skeleton Clock Inserts for Woodturners
Here is a good Canadian company.
Clock Fit Up Movements
