Aluminum closed end wrapped in Walnut.
More4dan
Katy, TX
I had this concept pop in my head this week and needed something to show at the Houston IAP meeting Saturday. I essentially made a very slender aluminum closed end pen then glued it into a block of figured walnut. Turned the combined aluminum/walnut block. It is currently clipless but a clip can be added to the cap. Its a throw back to the 70's based aluminum and walnut architectural designs. The nib is a #5 Bock. Cap threads are 11mm and the pen OD is 0.55" (14mm).
Danny
Simple elegant design is seldom simple. The thought and skill and planning are all there to see and admire....and I do.
Very nice looking pen. I had this similar idea for turning material that wouldn't easily thread. Such as alumilite with metal flake or other objects castes into it. Instead of an aluminum body inside I was thinking just to use some black alumilite, and also keep the end closed for the outside material. But I really like the look of the aluminum showing through on the end.
Very sleek!
Love it! looks like something that GQ would use as a prop for a photo shoot! Sleek and modern with a touch of retro styling! Beautiful!
Very sleek!
I left the aluminum thick on the end of the body and center drilled the end so I could turn the body between centers. After turning I faced the end enough to remove the dimple. A black core peeking out the end would look nice. My next chore is to taper the aluminum core and match the taper in the hole through the blank to add a bit more character/curve to the pen.
Thanks everyone for the kind comments. This one was an idea that popped in my head that I had to crank out in a very long day. I've been working out some tweaks in my head to upgrade the looks a bit. A better transition from the body to the nib, tapered/curved body, finding the right clip for the cap, and a reverse inly in the cap finial to reflect the one on the body. I've also got several TruStone blanks to add to the mix.
Danny
