Finishing Ziricote
TonyL
Georgia
First time that I am turning this wood. Seems very, very, soft. Does CA take well to it? Or should I just use a Pen Plus or WTF finish.
Thanks for reading.
Thanks for reading.
Tony that is just another oily wood. I have no problem using CA on any of the oily woods as long as I wipe thoroughly down with acetone. Let that dry before applying CA
I also just like to use a Danish oil on it and then polish it to a nice soft sheen. I did that with the base on this clock. Another beautiful wood to work with. The clock is Canary wood by the way.
Ziricote Exotic Wood & Ziricote Lumber | Bell Forest Products
I agree with John except I use alcohol - never had any problems. I was concerned with acetone because acetone will dissolve CA. Probably not enough acetone to effect it or it evaporates quickly, but I didn't want to take any chances!
I was thinking the same Steve so, I prepped two last night. I may finish one with PP and one with CA. I also coated the inside of the barrels with thin CA before gluing the tubes. It seems redundant, but the "drill dust" was so fine and soft, I thought it may help hold things together. Again, I am sure that step wasn't necessary.
Thank you for serving our country.
The PP came out good and I will handle frequently to see how it holds up. I will try a CA finish on my next go round.
