Cubism 2.0
Bob in SF
San Francisco
Picasso did Cubism 1.0 from about 1907-1921, but I'm no Picasso.
Cubism 2.0 is my idea of fun pen casting with variegated micro cubes that come out of silicone mini ice cube trays.
I'm new to this forum, so bypass this tip if it has already been presented by others.
It came to me when I was making some fruit drinks for my children.
This pic is self-explanatory:
attachment.php
Steps:
Add pigment or other little things to cubes
Pour on the resin (Douglas and Sturges polymer resin in this example)
Smooth over the resin with a stick
Pressure cast the cubes
Pop the cubes out
Recast the cubes with more resin in pipes or block molds
Cut, drill, tube, mill, turn, finish as usual
Have fun.
- Bob
PS: I use inexpensive silicone cube trays from Amazon - here:
http://www.amazon.com/Silicone-Mini...&sr=8-5-spell&keywords=silicone+minicube+tray
Thanks, Bob !
What pressure does that resin require for casting ?
Also, what is the product name of the resin please ? I can't seem to find it easily on their website.
Thanks, Bob !
I cast at 50psi - works well for me with polyester or Alumilite.
The Douglas and Sturges Clear Casting resin is well priced - $45.00 per gallon - here:
Douglas and Sturgess: Clear Casting Resin, 1 Gallon
- Bob
That's a really cool idea. The resin looks like Silmar 41, which many here use. You can find it from a couple of other places for a little less.
You might look at US Composits and Composite Envisions
Thanks for the tip.
EDIT: I do have a question though. You say you add the pigment to the cube then pour in the resin? You don't mix the resin with the pigment before pouring?
Thanks for the tip.
Hi Bob - sometimes I do premix and then fill the cubes, but I also like the extra surface "sparkle" and color intensity on the sides and edges of the cubes when I add (usually mixol) tinted resin which contains a bit of pearlescent pigment as a matrix when recasting.
I get my non-pearlescent raw pigments from Welcome to Sinopia Pigments - add a new dimension to your palette since I'm also painter and make my own acrylic, oil, watercolor, and pastel paints and chalks. I learned to make art media from the fine artists at Sinopia many years ago - really fine people (no financial attachment to them).
The resin cubes are fun to use, and you can make bags full of them in no time. You can also make some interesting bangles and other forms if you are into making silicone molds.
I caution that the cubes must be same type of resin as you use for recasting - the polyester resin doesn't work well in a matrix of Alumilite (or vice versa).
Best regards to all - Bob
(some of my other artwork and photography is here:
Bob in SF Gallery | Nikonians)
While I think they look neat and I can see the cubes in the unturned blanks I really don't see it in the turned pens. :confused:
Maybe I need a better closeup?
Hi Cliff - Sorry about low pic quality - here's a close-up showing cube edge detail - there are a lot of ways to make and use the cubes.
attachment.php
Best regards, Bob
attachment.php
Best regards, Bob
Cliff - Here's a close-up view of another "cubist" pen showing more "edge color pop" resulting from resin pouring into pigment and metal flakes preloaded cube tray.
attachment.php
Best regards, Bob
Thanks, Bob.
I often recycle resin fragments as well, and the smaller fragments can also be recast into cubes, then final cast into blanks.
Bob,
I really like this look and went ahead and ordered some trays to try it out.
Do you cut the trays down so you can get them in a Pressure Pot? Or do you have a big pot?
Not quite sure I understand about adding the pigment powder to the ice cube bin. Won't you just get the color on the bottom?
Joel
Hi Joel - Glad you asked - I no longer pressure cast the mini-cube trays - I just pour slowly to avoid bubbles. Sometimes I just want color on the edges, so I dust the cubes with pigment and mica powders, then pour in the resin - but more recently I've been premixing colors and pouring to get more vibrant cubes - like these:
attachment.php
I do pressure cast in a standard size pot (at 50psi) after I load my PVC pipe molds with cubes and pour resin over them.
Have fun! - Bob
Bob,
Mini cube trays just came--they look great. Can't wait to have some time to play.
Couple of additional questions....
Why aren't you using pressure on the mini-cubes? Any disadvantages?
Please describe your process for recasting the cubes into a blank. How do you make sure they don't sink to the bottom or float away? Any tricks?
Thanks in advance.
Joel
Hi Joel - I stopped pressure casting cubes because they were bubble-free so long as I did a slow pour of the Douglas and Sturgess clear casting PR resin -but you can do as you wish.
I then cast the cubes under 50 psi after I load them into white or clear PVC tubes or silicone block molds.
Since I use the same PR resin, the blocks don't go anywhere.
attachment.php
It's great fun, and opens up all sorts of creative possibilities.
Enjoy, and best regards, Bob
