Bodark (Osage Orange/Hedge) Pens
See more from rossvh
rossvh
Edmond, OK
A friend gave me some Bodark (also known as Osage Orange or Hedge) and wanted a couple pens. Very hard wood (and very yellow) that turns beautifully.
RossVH
it is one of my better choices of wood to turn, and crosscut is even better, but requires a sharp tool and patience. nice pens by the way.
Ross,
Can you tell me how you did the finish? My son just turned his first osage orange pen today. I am trying to get my kids more interested in woodworking. But where I'm failing is with the finishing. We cant get anywhere close to that shine. And orange is his favorite color, so he was really excited to find a wood in his favorite color. I showed him this picture, and he was very impressed! Thanks for any help you can offer.
Mark
Ross,
Mark
I use 5 to 6 coats of medium CA and then wet sand them with micro-mesh from 1500 to 12,000. Then I use HUT Ultra Gloss Plastic Polish to cover any small scratches.
I apply the CA in thin even coats and lightly spray NCF Quick accelerator after each coat. Do not get in a hurry here. Let the CA set between coats (several minutes).
I've done over 500 pens this way and if you use fresh CA you should have no problems.
Good Luck. Let me know how it runs out.
RossVH
Beautiful pens. !!
Finishing is... tough! And it changes for every different blank, and every different season (humidity in your shop...). Find your comfort zone, then tweak pretty much all the time. :rolleyes:
I prefer to "wet sand" with Walnut Oil and abranet 180 - 600. Then go to Pens Plus; or Danish Oil ( MM - 12,000); depending if I want a shiny finish or a matte finish. I rarely do a CA finish. And to complicate matters... At times I use a thin CA finish x2, then sand and finish with PP or DO.
Good luck!
Beautiful pens. !!
Good luck!
Interesting Mark! I totally agree with the change in temp and product, but now you got me thinking about other finishes. Thanks!
RossVH
Nice choice in the wood for your pens. Osage Orange is one of those timbers that just look great, without any fancy figure or burl. It is in a small group of timbers that one can make that claim for, such as lignum vitae, and some iron woods. Nice work!
Ross,
Mark
RossVH
Awesome. Thanks very much. Do you sand in between the coats of medium CA?
Great looking pen. I like the wood and make pens and calls for friends that like the outdoors. It's a pretty nasty tree with lots of thorns that people hate to have around but it makes for nice wood work. It will also turn a bronze color as it ages.
No I don't - unless I messed up when applying the CA.
RossVH
Thanks, Ross. I tried your technique last night and it worked out great. When I showed my son the results, he got excited to make his next osage orange pen. Really appreciate the suggestion.
-Mark
You're welcome! Having 2 pen turners in the family sounds like a ball!
RossVH
My boys are twins, so there are three of us! One of them just really took to the osage orange wood for some reason... The other one is a fan of maple.
Thanks again.
-Mark
Osage Orange was planted here in Oklahoma after the dust bowl by the many thousands. They are one of the best trees for a wind break.
The wood is very sensitive to UV and will turn darker over time, almost impossible to stop. Get ready for it.
I sit mine in the window to just go ahead and do it.
It is also the US champion for weight at 58 lbs ft3. Ok, the desert ironwood is heavier, just pretty rare and very expensive.
