JimB
I have some CA that is smeared on my faceshield and using acetone just makes it worse. If it was drops it would be easy to remove with a knife but it is smeared.
If your face shield has a replaceable shield, it may save you buying the whole thing. Good Luck!
It is replaceable and I have a replacement for it. I was just trying to get some more life out of it.
Be an el-cheapo, Put the spare sheald on but save the old one. It will be like you still have a spare.Acetone will remove the CA, but will also likely cloud the shield... DAMHIKT....
I keep 3 face shields in my shop with replacement shields for all of them...
Hi Jim....Have you thought about using Saran Wrap to protect your face shield?
You would only need to put it on as you do the CA process, when you have finished, you could rip it off and voila! you have a new clean face shield again.
Dave.
I have two face shields both from Habor Freight.
The cheap one and the more expensive one. I use the cheap one for CA.
Jim... It is very distracting to read your posts and this "Guy" on the upper left side of my screen is doing pirouettetes...
Oh, good luck with the CA issue... I'd buy a new cheap face shield. I use two - one for actual turning, kept clean; second with mucho glue splatters... used for CA/other finishes.
<<<<<<-------------- Are you talking about him?![]()
