jking
I have a question for those that have dealt with shaving brushes. I have a shaving brush that is shedding bristles and I would like to replace the knot.
Is there a good method for removing the old knot? I'm not really sure what I'll find, I planned to try to pull out the old bristles and then see what's left to remove. The brush came with a Van Der Hagen set. The handle is black plastic and has what appears to be a metal ring/band where the knot exits the handle.
I am assuming CA glue would be fine for gluing in the new knot? I also have epoxy (PSI epoxy I use on gluing pen tubes in blanks).
Thanks.
Thanks.
