TDE
Scott, you're having too much fun with that new mill. Will we get to play with it one day? I'm planning on making it down there one of these days. Ted
They're starting to get a little rough in the cut ....
You'll want to bring a small broom and brush off that railing that the power head rides on, the sawdust is making your rig bounce around a bit and that makes the cut ragged ... the other issue is a dull blade. Sharpen it before each job, perhaps? Also, don't forget to keep a spare or two in the truck!
My advice would be to invest in a good thickness planer....Yup ... I'll be expecting fairly rough cuts ...
I do have a decent plan though, for much MUCH cleaner cuts down the line ...
See, the chainsaw mill will be for basic slab work and quartering to get the logs down to a manageable size for my table saw. Once it's small enough for me to work on the table saw, I'll attach the slabs and quarters to a sled and run them through the table saw blade to get nice finish cuts all round.
From there it's simple trim work with either the table saw with a sled or my miter saw to make my blanks.
There's plenty of maple, pecan, oak, and mesquite around here for me to mess with.
My current main issue is just the run time with this chainsaw .... Black and Decker 20VMAX Lithium 10" Chain Saw .... I get about an hour with a full charge. I do have a spare battery, but it's a 2AH rather than the 4AH that came with my chainsaw ... the 2AH came with my weed eater.
Plus I'm gonna want at least a spare chain as well as a dedicated ripping chain with a spare for that too. I won't be doing the full size mill work, just going after free stuff that's laying around.
But first .. I need a place to work. My table saw is still in it's original box, because I have no room for it in my living room (where my lathe and other tools are).
There are a few tools that I have never been able to master....hand plane is one of them, also spoke shave the other thing that has always given me fits is sharpening blades on a wet stone. Oddly enough my dad could handle all of those things really well, but I could just never catch on.Electric = lots of heat during extended periods of cutting. Most of the heat generated during 'gas' milling is transferred into the oil reservoir and air flow being pulled through the saw.
I would recommend large fans blowing directly on the unit you have!
I use an upright bandsaw to reduce flitches/slabs into pen and bottle stopper/game call blank sizes. The bandsaw mill makes a finished side that is more then acceptable for consumers(that, and I don't charge folks an arm-n-leg for blanks)....planer would be 'nice' for pen blanks, but absolutely unnecessary. You could just as easily use a #5 or larger hand plane and those can be found at yard sales for less then you think.
Skie_M, feel free to PM me.....we can take some time to go over some of the things I learned along the way(maybe save you a few bucks in the long run)
Scott (hate wasting fundage) B
Why on earth would you think I didn't know that? I said I have never been able to master them not that I didn't know what they are or how to use them....I have a house full of rustic furniture, much of which I made myself (using a plane as little as possible and a spoke shave not at all).There are a few tools that I have never been able to master....hand plane is one of them, also spoke shave the other thing that has always given me fits is sharpening blades on a wet stone. Oddly enough my dad could handle all of those things really well, but I could just never catch on.
This link might give you a lot of nice hints concerning card scrapers ... and sharpening with wetstones by hand. https://www.youtube.com/watch?v=Nz6EpQu2HRo
Planers and spokeshaves are different.
A planer is like a chisel held in a handle at a certain angle ... I like to hold them at a slight angle to the work and run them straight down the grain. They make very nice fine curls of wood. These are more often used in fine woodworking and cabinetry.
A spokeshave does virtually the same exact thing as a planer, but rather than pushing it away from you, you use the handles to pull it towards yourself. These are used to whittle down planks and boards into rounded objects, like bows and wheel spokes for wagons. They are also commonly still used in green woodworking. These are most often used in bowyering and green woodworking ... rough rustic furniture crafting.
In some cases, you may find a planer that has a CURVED blade on it. This is for green woodworking, to leave a "hand carved" appearance on the surface of the work... You might find them in a furniture maker's toolbox if they like to do some rustic furnishings that appear at home beside some green woodworked chairs and tables.
Looks like tons of fun!
Oi .... quartersawn is some beautiful and highly desirable stuff, but you're right... it takes a LOT of work to do it!
Do you already have a "cut chart" to follow for your quartersawing?
You know every time you post these pictures of awesome slabs of wood, I think to myself "Man, I hate that guy!":biggrin:
The operation was a success!
I have another appointment on the 13th, and then I'll get to hear about all that fabulous time I'll be spending at therapy! My sawmill misses me....I walked out there the other day just to touch it(that only sounds weird when I read it now)....
Scott (milling to start soon-ish) B
It will sound weirder once your off pain meds.:biggrin:The operation was a success!
