Majestic Squire & Executive
See more from campzeke
campzeke
Tampa, FL
Here are a couple of my latest pens. The Majestic Squire and the PSI Executive. Both were made from Bronze & Gold Inlace Acrylester. No paint on the tubes.
Great looking pens. I could never turn Inlace blanks. They've always blown up on me.
I try to go easy drilling on my drill press. I turn it at +/- 2600 RPM using SHARP steel tools taking light cuts. I suggest you re-sharpen for your final cuts. Once I get close to where I want it I take VERY LIGHT cuts to about 1/16" or less from the bushings. From there I finish with sandpaper for final fit and shaping. I usually start with 80~100 grit and sand through 400 finishing with a full set of MM and plastic polish of your choice. I have had small pieces chip out but I think that was from being too aggressive or dull tools. Small chip outs can easily be filled with CA and turned or sanded smooth. I am not an expert by any standards but this is what works for me. Inlace is not the easiest stuff to work with but I love the end result. BE SURE to paint the inside of the blank and the tubes if you are turning a thin pen and don't want to see the brass.
Try it again and let us see your results!
