This contest is for those who are just starting out turning pens as well as those of who have been doing for a while, but just haven't mastered it yet. Here is a quick self assesment to determine if this contest if for you.
ATTENTION ALL TURNING CHALLENGED TURNERS
PRIZES WILL BE
First Place.....from Exotic Blanks $50.00 Gift Certificate
Second Place ...from Robutacion $40.00 Gift certificate
Third Place ....from Smitty a package of pen kits.
If I say "How is the Fit and Finish?" and your response is " Better than the Fat and Norwegion".
You're not quite sure what "outgassing" is, but you pretty sure if involves refried beans.
You wonder why California is the only state that gets a finished named after it.
The only reason you use a skew is to keep up on the latest swear words.
You've glued any part of your body to either yourself or anything your shop in the last month.
If you answer yes to any of these questions, this is your contest. So now that you have determined that this is indeed the contest for you. Here are the guildlines:You're not quite sure what "outgassing" is, but you pretty sure if involves refried beans.
1. A Slimline or variant must be used for this contest. Basically if it has a 7mm tubes, a twist 7mm tranny, and two equal length tubes its eligble. This includes Creekline, Saturn, Funline, Streamline, and Trimline kits.
2. You may do no alterations to the kit. (No custom centerbands, No closed ends, No hidden clips)
3. To keep the playing field level.....
6. The deadline: Midnight God's Time ( also known as Mountain Time) August 23rd
7. To enter email up to 3 photos to D.Oliver.IAP@gmail.com. Please put Turning Challenged in the subject heading. Photos must be sized 800 x 600.
8. Pens will be voted upon by IAP membership. The criteria should be considered in both the making of the pen and voting should be:
So there it is. Have some fun, talk a little trash, and make some pens.2. You may do no alterations to the kit. (No custom centerbands, No closed ends, No hidden clips)
Wood Lathe - Yes
Metal Lathe - No
Ornamental Lathe - No
Rose Engine Lathe - No
CNC - Oh H#ll NO
4. Blanks for this contest must be:Metal Lathe - No
CNC - Oh H#ll NO
- Commercially available
- Made by you from raw materials, where the work by you represents the majority of the work required to create the blank.
- WOW factor
- Fit and Finish
- Creativity
- Difficulty
Questions? Post them below or if you prefer PM me.
PRIZES WILL BE
