Vacuum PR before pouring
chartle
Pgh, PA
I've seen some videos where they put the PR in a vacuum pot for a few seconds before pouring to get the bubbles out. I don't have a vacuum pump and don't plan on getting one.
Do you think it would be worth it to use the accessory vacuum hose that's on my seal a meal and a small mason jar rigged up with the hose to give it a few seconds of most likely lighter vacuum to degass it?
I can't leave it running with some sort of chamber because the Seal a meal will only run for a minute or two.
Going to try a clear PR pour and there can not be any bubbles. The blank is going to take me 5 hours of hand work to make.
Don Ward - (Its_Virgil) has provided instructions/description on how he does it several times. Don casts lots of clear blanks. He does not use vacuum.
Its one of those things I have the seal a meal and the chamber, a marinating dish so I may try it this morning.
can't hurt
Ive casted hundreds of blanks, never used vacuum, dont see a reason too.
I use a pressure pot. Some will set the mold on something that vibrates to eliminate the bubbles.
Harry
Styrene is a solvent to make polyresin thinner and also helps in the cross linking for strength. The styrene will evaporate from the resin if the vacuum is more than 27 inHg. A gauge is important. When I was using vacuum I kept the vacuum at 25 inHg to prevent the styrene from evaporating. I no long use vacuum and haven't for several years now.
Do a good turn daily!
Don
Ok here is a report.
While the resin moved around a bit I didn't see any bubbles popping. So I'll stick with warning my resin on a candle warmer.
I also use it to gently warm the blanks as they cure in a water bath. They get up to around 140 f.
I can't help but ask, Can we have pictures of the results? Good or bad please share your learning!!
Thanks!
Check out Don's tutorial here.
http://content.penturners.org/library/techniques/casting_bubble_free.pdf
Not sure why he didn't reference it.
Lin
Thanks!
Here is my setup. But they are still cooking. After an hour in the bath they we're past gummy. But I haven't been home.
Done "cooking". There are done with alcohol inks. Epresso and copper mix ins.
I may get to drilling and painting tomorrow if I can get out and get some copper craft paint. And then turn them Tuesday.
