I like that William. What did you use to make the segments?
Beautiful, great job. As an aside, I made a 60 segment for my parents in celebration of their 60th anniversary.
Could we please see a picture of you 60 segment one.
As far as conventional segmentation goes this one would have been a 300 segment bowl because those are done by making separate rings and stacking them on top of one another . If I had staggered the rings , that would have shown up better.
I have made another board blank similar to this one except one type of wood is a different color . If I stagger the rings on that one after I cut them out of the board it will better show what I am describing .
With this one , it is a bowl from a board and I cut the 60 segments and glued them all up together into a flat board . Then when they were cut into rings to form the bowl there were five rings of 60 segments each for a total of 300 .
My bowl had 5 rings with 12 segments per ring. This was one of my earliest bowls and I was not happy with the shape of the bottom.
Could you show the various steps in your bowl? I am not following your process.
