BSea
For those of us who don't have a real shop, our toys don't always have a dedicated area. So they need to be stored when they aren't being used. For me it means that when I cast, I end up putting my pressure pot on a portable table, or my table saw (which is on a mobile base). So when I want to do a cast in a flat mold, I need to level my pressure pot.
After a couple of years of using shims (popsicle sticks), wedges, and other things. I decided that I needed a better way. So I bought some T style knobs with studs from Woodcraft. And used the 4 prong t-nuts to place in 3 corners.
In one corner I just glued on a piece of 3/8" plywood to make sure that the corner was lifted. I then drilled a hole in each corner for the 4 prong t-nuts and hammered them in.
Now I can level the pressure pot and not worry that a shim will slide out when I'm securing the top to the pressure pot (I hate when that happens
). Also, as long as I leave the t-handles in place, I'm close to level the next time I use the platform. I'm going to add wingnuts to use as locknuts.
