Sure, the main rubber seal is always the first thing people think when the pot   leaks but, if you have inserted the pot in water and you saw bubbles, you need to identify from where they are coming from as 50% of times, is not the seal leaking but, one or more of the connections on the lid that are leaking and to resolve the issue, you have to remove one fitting at the time, clean and put some white threaded tape and re-install..!
For the main seal, a dry one doesn't work as well as a lubricated one, Vaseline is a good product to use, but I use what I had in quantity  and that is some leather lube, I use on new and used leather working boots to maintain the leather soft...!
Remove the seal and clean the aluminium and rubber with some acetone or Methylated Spirits then, spread a small amount on both sides of the rubber seal and put it in place, it should stay there, if is the right size.  Make sure the lip/edge of the pot is wiped clean before putting the lid on.  Tight the nuts in cross orientations, as you would do in a vehicle tyre, this should maintain an even pressure on all nuts, failing to do that, the pot will leak every time...!
I have made myself a small wooden handle (
here @ post #54 to assist with tightening the nuts, my weeks wrists did need something to avoid further damage to them and the extra length allow me "feel" the pressure I'm exerting on each nut, in a more controllable/controlled way...!
Have a go and let us know...!
Cheers
George
