Need tube dimensions
Monty
Group Buy Coordinator
Pearland, Texas, USA.
Can someone please give me the measurements for the CSUSA bullet razor and/or stand? I know the tube is 7mm and the bushings are .472, but how long is it?
Nope, not online in the instructions (the first place I checked). It gives the tube diameter as 7mm and the bushing size, 0.472, but not the tube length.
Mannie, CSUSA sells the tubes as a separate item so I think if you call them they could tell you the length....It looks like the kit itself is a little bit forgiving but my guess is going to be a tad less than 2 1/2 inches.....but that is a guess.
I have one of their handles downstairs in my "Now what to do with this" stuff. I'll check the length later tonight when I get home.
Neither instruction set addresses tube length....just blank length which is longer than the tube.
CSUSA told me the tube length was 3 inches, but I'm beginning to wonder if that is correct since it says use a 3 inch blank and cut the blank 1/4" longer than the tube.
But it's more than likely a moot point now since Fred is making the molds for 3 inch tubes for the Artisan razor and stand. I suspect that if the tubes are slightly shorter, the mold could still be used for the bullet razor and stand.
They lied Mannie - it can't be 3 inches. You could not follow their instructions for squaring if it were...I wish I had one to measure, my bet is 2 1/2 inches, possibly 2 5/8 but no longer.
