Show me the top of your pressure pot
Dan Masshardt
Mechanicsburg, PA
I'm getting set up to start casting.
I'm curious how similar / differently people have their pressure pot plumbed.
Take a shot of the top so we can see. :-)
Thank you!
Here's what I've got. Made it as simple as I could. It's just a simple 1/4" brass nipple hooked to a cross the gauge (purchased from surpluscenter.com) shows both vacuum and pressure, the 1/4" cutoff valve came from home depot in the air tool aisle, The female adapter in the back is for future vacuum endeavors. Don't try to re-use any fittings on the tank, throw them all away. I did however re-use the air dispersment fitting on the bottom of the lid. Buy all the fittings you can from the air tool aisle rather than the plumbing depth, saves $
It is if you are using vac and pressure simultaneously. Just saying. I love the versatility.
Lin.
Hi Lin, using vac and pressure simultaneously would be a neat trick..:biggrin:
Just kidding, I know what you mean.:tongue:
Here is my simple set up...
The gauge is from Vac to 7 bar so can handle both and is mounted on the pressure relief valve ( which I have calibrated )
Then just a good non-return valve to connect either my vac or compressor.
Edit; added a close up of the gauge:wink:
