Another Pentel Conversion
See more from Dale Parrott
Dale Parrott
Goshen, Indiana
I'm still making these and getting better with the finish. This Pentel was made from 45 degree cut Texas Mesquite and has a CA finish that feels like glass.
Hope you like it.
Pentel Conversions
Real nice fit and finish. I love making the Pentel conversions, and others enjoy their reliability. The only thing I, and the others, dislike is having to use the Pentel clip if a clip is desired. I would love to find another clip, or a way to attach a clip in a different way. Anyone out there with any thoughts or successes with other clips?
Here's a way to incorporate a different clip. Make the original blank a little longer, cut a 1" piece off and drill to fit a tenon on the lower piece which has the OD of a clip ID. You can also make the push button by using the original as an insert to what ever you choose. Just make the top hole a little larger to fit.
attachment.php
attachment.php
That's an interesting concept Bruce and may just have to give that a try. I am curious as to the nib in your picture as it doesn't look Pentel.
The nib is custom as well. The threads on a Pentel are 4mm x .5. I made a brass insert for the nib with those threads (tap bought on ebay). The hole for the lead is made using very small drill bits - I think its a #62 or close to that for the 9mm lead. A little tricky to get it centered but achievable.
