hombre4
Who has the best prices on their CA glue and 5 minute epoxy?
Thanks....Archie
Thanks....Archie
Thanks....Archie
It's not epoxy, at least not like we normally use. It does appear to be more like CA in that there is a thin , medium, thick, and a gel. It says you spray the activator, then the 2p10 bonds in 10 seconds. I could not find anywhere that said that you could use it without the activator. I also didn't find anywhere that said the word Cyanoacrylate.2P10 appears to be an epoxy, not a CA.
Compare products and prices carefully to be sure they are actually the "same".
Thanks, that's good information.I use it all the time. You do not need to use the activator unless you want the 10 second cure time (or faster!) I've got a bottle here in my hands and it does say "Contains Cyanoacrylate" Call FastCap for more technical info at 888-443-3748.
What is BLO please? Thank you.
