Chucks Components or Alumisaic
See more from Dalecamino
Dalecamino
Local Chapter Leader
Indianapolis, In.
It's been a long time since I posted a pen here. So, I thought I would use up some of this aluminum stock I have. Also, not going to be calling these pens kitless any longer since, the parts pretty much DO make up several COMPONENTS. With the exception of the clip, nib and, feed. The blank is a Green Mosaic, the components are aluminum (except in the UK where, it is Aluminium) :biggrin: Thanks for looking!
Chuck,
I'm sorry, but there are too many flaws in that pen to post it. I suggest you take down the pics and send the pen to me for some extensive repair. It might take a couple of years to fix everything . . . .
That is superb Chuck! Beautifully made too!!:good::good::good:
However, it's only Americans that spell aluminium incorrectly.......:wink::biggrin:
Chuck,
LMBO! Sorry Dave, I must disagree with you this time :biggrin:
HaHa! Thanks Steve. I thought you would like my spelling of Aluminium . Although...my spell check just told me I've spelled it wrong.:wink::biggrin:
Nice pen Chuck. I like the style of the aluminum parts that you made. Not sure what the definition of kitless is but it seems since you made all the parts?
You still got it Chuck!
Thanks Derek. It was a little shaky based on my memory and, misplaced notes :rolleyes: I had to rely on Mike Redburn for a little reminder.:redface:
That's a classy looking pen.
Thank you Jim.
Great pen! The aluminum components turned out really nice. I was just wondering why I hadn't seen this type of kitless before.
Thanks very much. I haven't been able to make one of these pens since last summer due to moving and, WINTER :frown:
A Beautiful pen, Chuck,
Looks Fantastic regardless if it was made with Aluminum or Aluminium,
Outstanding Components, and Superb Blank.
Congratulations.
BTW, it's Aluminium Down Under as well.
Brian.
Awesome!!!
Chuck,
I love this pen!!!! The mosaic with it's understated grey and black tones ties in beautifully with the components you made.
Hmmm...missing something though..usually more prominent in the center area of the pen sort of at the lower end of the cap...lol
Just kidding... Perfect as is...a more prominent center band would distract from the beautiful mosaic. It's truly a gorgeous pen and I wish it were mine!!!
Regards,
Doc:smile:
Chuck,
Regards,
Doc:smile:
SIGH! There goes his hat size...............:eek::eek: :biggrin::biggrin::biggrin:
Looks great Chuck! Very nicely executed "components".
How does the aluminum to acrylic threading feel when capping the pen? Any concerns with a cross thread with the aluminum cutting it's own threads in the softer acrylic?
Im glad to see you posting!!! awesome pen.
Thanks Mark. So am I! :biggrin: It was a long dry spell with no turning.
Man I like that - sharp look - I love the components
Thank you Keith!
Congratulations.
Brian.
Thanks Brian. I was just teasing Skiprat :biggrin: and, now you :biggrin:
Chuck,
Regards,
Doc:smile:
Thank you Doc. I left the extra band out just to see if you would notice :biggrin: Joking of course. I was just plain lazy. :rolleyes:
Chuck,
Regards,
Doc:smile:
Not yet! The one I have may be stretching a bit :biggrin:
Thank you Carl. So far, there has never been a problem with starting the threads. I'm sure it could happen but, so far the threads start perfectly smooth.
That looks terrific Chuck, very nicely done! I like those aluminium parts.
Mike
Thank you Mike! I have a couple more ideas. Wish I still lived in Florida right about now. Access to that mill would be nice.
I have a couple of those mosaic blanks. Still have not turned one yet. Don't think i have green, but from what i can see it looks very nice.
Pitoon
Chuck,
What do you think of a front section made out of aluminum? Serious..no joke!
Doc:smile:
I considered that Doc. When I made a BP pen with aluminum section, I thought it would be nice to make a FP section the same way. Unless it has a coating of some sort, it will turn your fingers black. I don't have a powder coat system and, tried a poly coat but, when I started sanding it, peeled off the section. Haven't tried clear coat yet. So, maybe in the future, I'll try again. Made this section with a PR or alumilite blank that, seems to be pretty soft. Is a bit hazy when polishing. Don't recall where I acquired it from. I am looking to restock with some good ebonite. Thanks Doc!
Chuck! Great looking pen mate, i luv your design and material used,i was wondering the size of the tap/die you used and the length of the pen thankyou in advance.
Thank you John! I use the 12mm triple start tap & die from Mike Redburn for cap & body. The finials are 9x.75 tap & die. The pen measures 5 inches capped. Both finials are drilled out to keep the length minimal.
Pitoon
Thanks! It IS a nice material to work with. Polishes really nicely. Try it out.:wink:
CHuck
Anodize the front section no black rubbing off on your fingers.
CHuck
TeeHee! :biggrin: Completely forgot about that :redface::biggrin: When I get space to set that stuff up maybe :biggrin: Thanks Mike!
I used a coating suggested by Caswell called VHT. The coating sprays on and is hard and glossy and doesn't require sanding. Anodizing seems a more practical and permanent solution. I don't know how to anodize but would love to! I want to work with steel (Damascus/Koftgari) and have ordered a foot long rod of Koftgari...ought to be interesting:eek:.
Doc:smile:
Thanks Doc. The VHT would be a simpler way to go. Although anodizing IS fun, there are steps that, require more attention. Time in acid bath, time in the dye (or not if, you want clear) current, conducive connections etc. but, the results are satisfying :biggrin:
