Has anyone ever tried mixing food coloring and denatured alcohol? I was thinking about trying to dye a blank and all I have on hand is food coloring. My thought are if I use the denatured alcohol I wont raise the grain.
Are you talking about just let the wood soak or put it under vacuum...???
Without the full vacuum, most woods will only soak at the surface, a couple of millimeters in and you got nothing however, if you are thinking in putting a mix of denature alcohol in you vacuum chambers, STOP, you will destroy the pump oil, and possibly cause considerable damage to the pump, believe me, I know, I've tried various solutions to dye wood and none of them had much penetration, using the vacuum pump/chamber to force some of those solutions into the wood, didn't work as expected with the worse being the dye mixed with the denature alcohol, the vapors created were a nasty thing...!
If you are trying to dye blanks for your own usem save yourself some money and lots of time by, simply dying the turned barrel when gets to finished size, it takes 30 seconds using a bit of cloth and the dye/colour, burnishing it against the wood, the friction heat generated, will dry the little wood the barrel has.
If you want to be sure, use a heat gun or a hair dryer to dry any moisture from the dye, burnishing it will leave a smooth finish so, you can apply a couple coats of thin CA before you touch it with any fine grit sand paper, the rest is done as any normal CA finish...!
I hope this helps...!
Cheers
George
Thanks for the help. We went to A.C. Moore this morning but we could not find the dye. We ask but no one could tell us were it could be found or even if they carried it. We ended up getting some gel food coloring and oil based paint. I'll play around with them to see what I can come up with. I have a few light colored blanks I can play around with.
Thanks Harry. I'll try to find it. I used gel food coloring and DNA on this blank and few coats of WTF. I guess I should have let it try longer (I'm not sure how long to let it dry) as I got some blue come off as I put on the finish. I'll turn this blank down some more them I'm going to try some oil base artist paint next I'll try it straight out of the tube to see what happens.
Would distressed ink (or anything else from the embossing aisle) work for enhancing the appeal of the grain? As I have so many walnut blanks, I may have to do some experimenting!
