Rounder
This is a banksia pod from George's last batch. These things are FANTASMICAL!!! SUPERCALIFRAGILISTICEXPIALIDOSIOUS GOOD!!!
Took me a long time to do. I took it very slow as the stories of messing up these beautiful blanks abound. I tried to use the flap disc as George suggested, but I didn't feel comfortable using it. I didn't feel I had the control that I wanted for such an awesome piece. I used a homemade carbide tool that I normally turn with. I stopped every couple of millimeters and applied super thin CA as suggested. You could actually feel the difference in the blank (by touching) when it was time to add more CA. The pod area would feel raised above the resin area and then I soaked again with CA. When I thought I had it turned down to size, I added CA again then turned it down to size again. Did that several times. Then I added 20 coats of medium CA, dry sanded both directions with 240 to 600 Abranet and 1800 to 12000 micro-mesh. Then wet sanded with 1800 to 12000 micro-mesh, a good coating of #2 Novis fine scratch remover and finished with the Rennisance wax. ME BE VERY HAPPY!!! I do think the blank was too good for the kit. I will have to find a better kit to fit the status of the blank on the next one I do.
Thank you George for the beautiful blanks. I am not a very experianced turner but I studied your directions and took my time and was GREATLY rewarded!!!:biggrin::biggrin::biggrin:
