Is this possible?
Haynie
Page Arizona
Can you chop an old file to size, grind it down and make a skew out of it, or is it the wrong type of steel?
I don't see why not. As long as you dip the file in water as you grind it, before it starts turning blue it should keep it's temper :eek:. I piece of clod rolled steel might be a better option (Lowes/ Home Depot, etc.); high speed steel would be better. I'm not sure where you could get that though.
Files are brittle and subject to breakage. You can use an old file for turning tools but beware of this factor which is inherent to the heat treating process of files.
I have seen lots of tools made from files. They do work fine and you only invest the time to grind them.
Old planer blades are better if you can find them since they are HSS.
Wrong type of steel, file steel very brittle. Many people recommended making scraping tools from old files when first got into woodturning. Today most folks with more knowledge than I about steel say no-way. I agree, life too short to risk hurting yourself!
Roy Underhill did a show where Irish turner made his skew from old Chevy truck springs. He also forged other tools from that steel, but man has blacksmith experience.
As much as I would love a carbon steel skew, life too short to make my own. I own about five or six various size HSS Skews. My two carbon tool steel skew too short to do much damage these days.
vehicle springs are normally 5160 ish from what I have been hearing.
Bummers. I need a short skew or angled scraper, not a full length one for what I want to try. I only have one set of tools and I'm not chopping any of my turning tools.
I have some scrap cold rolled I can shape, but I assumed it would not hold its edge. Is that right? Local metal place does not carry HSS or tool steel that I know of. The only way they will order it is if I by 10 lengths. A length is 20 feet. I don't need 200 feet. I am sure that is how they avoid dealing with little people like me.
use the cold rolled to form the body and create some type of holder for the small cutter head. broken lawn mower blade would suffice for most of this actually.
I am thinking of ordering one or two of these to make some custom tools.
From Enco.
If you are thinking of making a tool like the Japanese pen turners use go ahead with the file. My Dad used a number of files for turning including a Farriers rasp and it was old age at 91 that took him. Not a broken file. Then again maybe old Danish
woodworkers are just incredibly lucky. ;)
Many folk have made 1/4", and larger round skews from drill rods and HSS rods for not much money. Same with HSS bars. Take a trip to the grinder & homemade tool handle & you are in business.
