Skew
dfolk
Alabama
I think I finally figured out how to use my skew. It has been kicking my ?!€& for a few weeks so I watched a you tube video to learn how. 90% of the video concentrated on sharpening, I guess for good reason, I picked up a diamond card and my next attempt was surprisingly effective. I turned an acrylic blank to the bushings with ease. It's an effective tool when you finally figure it out.:biggrin:
I prefer to put a flat grind on the skew. It doesn't catch as much. Sharp, sharp, Sharp!
I use a 12" disk sander to sharpen the skew. I can hone the edge about 10 times before I need to go back and sharpen on the disk sander. The disk sander takes off smaller amounts of the tool, so the tool lasts longer.
I found that Alan Lacer's grind worked wonders for me. I have converted several skews to his grind and it made the difference between frustration and success for me. I use a skew far more now:biggrin:
I'm still learning to use a skew but when I have it working right it's great. It's a really important tool to learn to use.
The reason I can't use a skew right,is I just can't coordinate myself to flip it over and go frome left to right.I can only go left to right.Just the same if I try to write left handed.
But I can go right to left if I use it as a scraper,which does not work good.
So I got a Woodchuck,& do good with that.
Anybody else have that weird problem?
Steve
