What oil for vacuum pump
This is the stuff I use. It is good for just about any type of pump including reciprocating piston or screw.
There is a web site shown on the back and you can get a list of their stockists on their site.
I'm sure you can get similar stuff in France, but UK isn't too far otherwise.
Good luck
I purchased mine from a local auto parts store.
I would assume there are auto parts stores in France and that they sell supplies for auto air conditioning equipment. The oil would be used in vacuum pumps used for auto AC repairs.
Hello Plantman,
No, there is not.
PS: Who could say me the characteristics of oil JB DVO (viscosity, ...)
The lower the number, the thinner the oil. In extremely cold weather you wouldn't want to use straight 30 weight oil. It will get very thick and make your pump or motor hard to turn over until it warms uo. To thin of oil, such as 5 weight, will get thiner in very hot weather. Most people in the USA will use a 10-W30 or 5-W30 in their cars, because it is a blend of oils that will cover most temps. No Walmarts ???? Do you have something like Walmart?? I would go to an auto store to find oil for your pump. Maybe a full service fuel station?? Good Luck!! Jm S
I Googled "vacuum pump oil" and found lots of oils made expressly for vacuum pumps. Lots of leads in the Images section too. If you do the same there should be lots of local sources in France and surrounding countries.
Please do not use motor oil of any kind in your new JB pump. It is made to use vacuum pump oil and only vacuum pump oil. If you must, vacuum pump oil is highly refined mineral oil so you could get the purest mineral oil you can find it may do. Why not just order some real vacuum pump oil to preserve your investment? If you were able to buy a JB in France, you should also be able to buy the vacuum pump oil from the same place. There is no substitute for good quality vacuum pump oil in these pumps!
Heck, I bought a new, cheap Robinaire vac pump as a backup. It came with Chinese vacuum pump oil. I filled the pump and ran it to see my maximum vacuum. I was pulling 28.5" Hg. I then drained it and refilled it with JB vacuum pump oil and it pulled 28.75" Hg so good quality oil does make a difference.
Don't ruin your pump by using just any old oil!
Yes, I agree, vacuum pump oils are very specialised oils that you don't find in hardware stores, autopro -shops or similar, not here in Australia, I made the mistake of not buying 1 gallon of this oil when I got the 2 stage pump or soon after and at the moment I have the pump without any oil as the one I had got badly contaminated.
I've spend most of the day looking for this oil type the the biggest town next door and came home empty handed. Most people never heard of it and try to convince you that any of the thin oils will do, and if you aren't properly informed, you endup buying t\what they want to sell you and you ruin your pump, simple...!
However, not "common" in most stores, is nothing that special about this oil, apart from being nearly as thin as water and used on something that is not an everyday type tool so, stores don't store it, despite of this, I can not see how eBay seller in Australia, are trying to charge $99.00 for 1xgallon + $20 odd bucks for freight, that is just robbery...!
I've seen some places in the USA selling this oil in gallons (US gallons) for under $40.00, that seems to be a much more realistic price for 3.7lt of this oil however, the shipping they want to charge to send it here, would make it $100 plus...!:mad: damn if you do, damn if you don't...! bugger.
The worse part is that at the moment with the holiday season upon us, most specialised shops have closed a week ago and many will only open after the middle of January 2013 so, my mistake of not thinking of this, a couple of months ago, silly me...!:frown:
Cheers
George
