plantman
C&C welcome. Hope you enjoy. Jim S
Not sure what camera you'll be looking at, but if you end up buying one of the prosumer DSLR cameras, be sure to set the focus to manual. Most people will set the camera to full auto and the cameras have a way of picking different focal points. If you do this manually you'll find the results are much crisper. You'll also be able to play with different Aperature settings and stops that will increase the dynamics of your captures.
P.S. I put a dark spot on the top of the tooth and added a crack between the roots on the front. What is a Dentist going to do with a perfect tooth. Jim SI think I have solved the problem I was having with the yellow tint on my photos lately. My daughter-in-law, the pro, came up for the weekend and looked over my setup. The problem was the energery saving bulbs I had changed over to. Even though they are daylite bulbs, they throw a yellow cast. We also ordered a more up to date camera. Here are the results. No yellow tint, better quality and detail. First is a PSI Tradiional Fountain Pen with a realy wild grained Oak blank, and a CA finish. Second is a PSI Magnetic roller ball in Gun Metal with a metal flaked flag on an Antique Ivory blank finished in CA. Next is an old kit I had in a Drawer from CSUSA with no name. It's a Gun Metal and Black roller ball with a Tulip Wood blank and CA finish. Last is a pen from Lazerlinez with a PSI Gatsby kit in Gun Metal and Black with a CA finish. Quess who is getting this one.
