Robert111
I wonder if anyone has a suggestion for getting the pattern or grain to match when doing the clip joint (cap/finial).
Here's the process I've tried with little success:
1. Start with a round blank for the cap, about 18 mm in diameter, drilled out and threaded for the barrel (body).
2. Part off the top 3/4".
3. Drill both the finial piece and the cap piece with 9mm bit.
4. Thread both with 10 x 1 tap.
5. Make a shallow recess for the clip ring in the cap piece.
6. From another piece of material (black ebonite), I make a tenon 1/2" long and .8mm in diameter and thread with 10 x 1 die.
7. Cut slot in one end of threaded tenon for a screwdriver.
8. Assemble finial to cap using tenon and with a screwdriver, TRY to adjust the finial so that it mates to the cap grain or pattern.
I fiddle with adjusting the finial and eventually I can get the grain just right so that I can proceed to turn the assembly to shape and finish. Then I have to disassemble, fit the clip, and try to reassemble the finial, clip, and cap and get the grain to align again. Drives me NUTS!!!!!
