Mini Stylus
See more from Dalecamino
Dalecamino
Local Chapter Leader
Indianapolis, In.
These things should come with your phone.:rolleyes: I got this mini kit from Ernie at Beartoothwoods.com Used a blank Neil (wolftat) sent me, and Susanne is quite happy now. But, I guess I was supposed to get her one long ago :redface:
EBorraga
Passed Away July 17, 2022
Louisville, KY
Haw can Blue possibly match her Red phone. As you know i'm biased, I don't even own a blue shirt. But it still looks good Chuck. Maybe I should make her a red one and mail it to her:biggrin:
eupher58
Utica Illinois
Those little things are a breeze to make, 3 or 4 at a time, and are a GREAT seller! Just ordered more again tonight from Ernie. I cant make em quick enough....
Dalecamino
Indianapolis, In.
Just another example of gender-based guilt.
Tomas:)
I suppose so :biggrin:
Here you go Ernie. I have a strategy :biggrin: Don't do the whole job at once :wink::biggrin:
Joe S.
South Lyon, MI
So I'm guessing that's not you on your icon:biggrin:
rich gubbin
leicestershire UK
hi all,
On the subject of stylus,s/styli. Does any one else have a problem pressing the business end into the barrel. Im talking about the possibility of the rubber splitting. I,ve drilled out a bit of wood just big enough to insert the rubber and then press the tip into the barrel. This seems to work for me.
Andrew_K99
Waterdown, ON, Canada
hi all,
There is an installation tool (a little sleeve) that is required to install the business end of the stylus.
Edit, maybe not for the one's that BTW sells? Here is the link for the one that CSUSA sells for their kits.
AK
Dalecamino
Indianapolis, In.
hi all,
As the instructions say, drill a 1/4" hole in a piece of wood, then put the rubber tip into the hole, and press it into the tube. Proper alignment is important.
NC Wood Art
Portsmouth, VA
I actually make mine with the brass tube from the fan pull kits they are just a little longer & seem to fit the hand better, you could also just but the longer tubes & cut them down. I dont use not special too for assembly I just press it in with rubber cap on it right up against the aluminum pusher on my pen assembler. Not a problem yet. They are fairly tough piece of rubber or whatever it is made of. I also add a small drop of ca to both ends before pressing them in.
Bill
eupher58
Utica Illinois
If you have a bushing set for a "b" mandrel, the hole is just right. I use an El Grande bushing and it shoulders in perfect.
Dalecamino
Indianapolis, In.
I did consider using some longer slim tubes, that have been laying in a drawer for 4 years. They'd have to be more comfortable than these stubby things. Thanks all for the input.
