iPad stylus
See more from Penultimate
Penultimate
Bartlett, IL 60103
Greetings
I've had a tough time finding a stylus that worked well and felt good while writing. I've used rubber tipped, plastic discs and conductive fabric, but there was always some issue. I like how conductive fabric feels when writing because it has less friction than a rubber tip and is not as squishy. I got sample of the fabric from Lessemf.com.
I used a Rockler toolbox pencil with a metal chuck since I could experiment with the diameter and shape of the nib. I cut a 4mm diameter rubber erasure at an angle like a felt marker tip. That gave it enough area to work on the screen. I then cut and wrapped the stretchable fabric over the eraser and shoved the assembly into the pencil chuck from the back end. That ensured a nice tight fit. The lower barrel is Aluminum and the top and finial are desert ironwood. It is finished with 10 coats of CA with a final polish of McGuiers plastic polish.
Comments are always welcomed.
Greetings
Got a link to the page on www.lessemb.com where you found the fabric? Haven't been able to locate it.
THANKS,
Barney
