50 Caliber Tooth Pick Holders
See more from rd_ab_penman
rd_ab_penman
Red Deer, Alberta, Canada.
Turned using Birdseye Maple.
Sanded to 400x, buffed with super fine steel wool and applied 6 coats of MINWAX Oil Modified Water Based Polyurethane.
Got to like this stuff as it dries hard within 1-2 hours compared to the Oil Based with takes 4 hours to dry hard.
Also the Water Based dose not jell in the can after a time exposed to air like the Oil Based.
Les
Really great idea and the execution of the design looks flawless! I bet you could sell these along with the 50 cal pens as a set and make a killing.
Neat idea Les
I saw someone on another forum using a similar idea for a pen, rather than using brass cartridges.
Neat
Awesome work as usual Les.
Thanks for all the info on another site about that new finish you are using.
It was great looking, I mentioned it in a home shop forum in a discussion on the 50 cal pen kits. And a member from down under said that a Les from Red Deer, had posted them on a wood working forum there. So it probably is a little late in the game for the proprietary/copyright thing. As they are very well known on the net Or it could be the bandwidth on his bucket account is maxed out this month!
The guy form Aus said that he had made one for a co worker, who forgot and had it in his pocket when going thru the UAE airport(Untied Arab Emirates). He had to spend the night in a cell till they sorted it out.
:clown:
Not sure if I'm supposed to do this or not but here's the pic I saved in my "I wanna try that someday" file.
Les,
Can you provide the general dimensions for the toothpick holder.
I'd like to copy your idea for a gift to my future son-in-law IF you don't mind.
Also, I found Paul Sherman's 50 Cal. tutorial for pens; I can probably pull dimensions from there and the 'net.
Thank you
Gary
