grz5
I've applied about 10 coats of minwax clear gloss spray lacquer to finish some pendants.  The finish was applied in light coats where I was spraying from about 12" away.   I've noticed that the spray lacquer leaves a surface comprised of many small bumps instead of a smooth one.
I've seen people mention that as the lacquer cures the finish with smooth out. Is this true or should I consider attempting to sand and buff the finish to smooth it out?
Any advice would be greatly appreciated!
Thanks.
Thanks.
