Sketch Pencil
See more from BW Design Works
Lake Stevens, Washington
This was a pencil I made for a great man. He loves to draw and spends a lot of time doing it. I used Black and White Ebony, then put a Celtic Knot in using Ebony.
Thanks for looking. Any comments welcomed.
That is a real beauty! I hope that I can learn how to do a Celtic Knot someday,are they as hard to do as they look?
Great job!
Steve
AWESOME work! I commend you on having the patience to do the inlay! That sort of patience is something I lack. lol
I've been wanting one of those sketch pencils for use in my work shop.
Again, AWESOME work!
Great job!
Steve
They can actually be pretty easy. You just need a jig that allows repeatability in your cuts. Then you just match your inlay material to the kerf size. There are one or two tutorials in the library that will walk you through it.
To the topic, that is one fine looking pencil.
Thanks guys! It's actually a great little kit. I like the fact that it has a sharpener built into the cap. Won't get lost that way :biggrin:.
@ Steve:
The knot wasn't to difficult to pull off. Sbell111 is correct that once you have a jig set up it's easy to complete. Just make sure your inlay stips are the same size as your saw kerf. I made these on my table saw because I wanted a thicker knot, but you can use a band or scroll saw.
@Drstrangefart:
Is that Mancow from Chicago?
@Sheumais:
You can pull this off.
