First peppermill?
See more from sbwertz
sbwertz
Phoenix, AZ
I want to make a peppermill for my DIL. Any suggestions for which kit to use? I am a relative beginner (been turning a year, now) and am comfortable drilling on the lathe. I just don't know what the differences are among the various mechanisims and designs.
PenMan1
Eatonton, Georgia
Sharon:
The mechanisms that Exotic Blanks sell are German made, are a good quality, and the shaft can be cut to make a mill anywhere from 4 inches all the way up to 10 inches from the same parts.
These grinders are much better quality that the ones I bought "someplace else".
PenMan1
Eatonton, Georgia
I really like this "adjustable" set because you fit the mechanism EXACTLY to your blank, You do NOT have to make the mill conform to the mechanism.
sbwertz
Phoenix, AZ
This is why this forum is absolutely invaluable. I would have just ordered something from PSI or CSUSA. Now I know. I'll order today
KenV
Juneau, Alaska.
More tools Sharon -- you will need forstner bits
1 1/16 and 1 5/8 are normal sizes at the bottom with 1 inch for the barrel size being common.
Carbide is good as are the colt brand bits --
There are some neat design opportunities for the shape -- I look forward to seeing you end product.
witz1976
Bucksport, Maine, USA
Sharon:
Andy I am 99% certain that the mechanisms are USA made...not German.
ed4copies
Local Chapter Manager
Racine, WI, USA.
That is correct, sorry Andy, they are made in Pennsylvania, by Chef Specialties. I have a letter from their president confirming actual manufacturing, not just labeling parts.
Now, our refills.................................are made by Schmidt, in Germany!!!
ed4copies
Racine, WI, USA.
Sharon,
If you have not already done so, request my tutorial via email---PM me with your email address and I will send it to you.:biggrin::biggrin:
Several tips that make peppermills a little more manageable!!
Good turning!! :biggrin::biggrin::biggrin: and endless drilling:mad::mad::mad:
PenMan1
Eatonton, Georgia
Ed:
The adjustable set I got as a Christmas gift (they said it came from you) says right on the bottom: "Made in Germany"?
Maybe my set came from somewhere else?
ed4copies
Racine, WI, USA.
Andy and I have worked this out, privately---his wife is forgiven for getting ONE mechanism someplace else. But the one labeled "Germany" did not come from us.
Yes, I will still be speaking with "PenWife1" when Christmas comes, I suspect!!
Thanks to you both for your friendship!
broitblat
Bellevue, WA, USA.
If you don't already have it, you'll likely need an extension for your forstner bit (unless you make a fairly short or segmented pepper mill). In another thread you mention you already have forstner bits, bit if you don't have the 1 1/16 needed for the mill, I just bought a carbide bit from http://www.woodline.com/p-2289-1-116...stner-bit.aspx
and was very pleased with how it cut through about 9 1/2" of Myrtle (only used it once, so far).
Note: The components from Exotics and some of them from CSUSA use the 1 1/16 (and 1 5/8) holes, but if you get you kits from somewhere else, they might use different tooling.
I also look forward to seeing your results.
-Barry
juteck
Charlotte, NC
I just saw Dick Sing demonstrate turning the 4" pepper mill which did not require the use of extensions for the Forstner bit. His comment when someone asked why make a small 4" mill -- 'how much pepper do you need before you need to refill with fresh pepper?'
I've made a 6" mill, and for home use, pepper lasts a long time. You can still get a nice shape on the 4" and 6", but longer ones allow you to play a little more with shapes, but you may need the Forstner bit extension. Shorter ones will get you started to see if you like making them.
Unless you know you're going to make a bunch of mills, I'd start with less expensive Forstners. Colt makes a good bit, and has a neat MT adaptor that fits in your tailstock instead of using a Jacobs chuck.
sbwertz
Phoenix, AZ
I'm planning on 4 or 5 inches on my first one. She doesn't like the great big ones, and it is for a gift, so I'll make what she wants.
ed4copies
Racine, WI, USA.
Consider that the top has to be gripped to turn the mill.
So, if the body is 4" (yes I use one that size every night, but it uses a handle, instead of turning the top), you will have a top that needs to be nearly half the size of the body---
CAN work out fine, just draw it out first and make sure you like the profile.
FWIW
juteck
Charlotte, NC
bradbn4
Colorado Springs, Colorado, USA.
Sharon,
I guess you only send out the instructions to folks that have a name starting with the letter "S". I will try to PM with e-mail again.
If my pepper mill kits arrive Friday I know what I will be doing this weekend.
Bradbn4-In Colorado
