CA REMOVER?
jim_colo
Pueblo Colorado
I did it! :bulgy-eyes: Yes to much CA!:mad: What is the best CR remover?
If possible, I would put the blank back on the lathe and either turn the excess off with a skew or sand it back -- then re-apply CA.
I have never has acetone work that well to remove glued fingers.
Try using a 'sharp' (new blade) craft knife. You can 'gently' run the knife at the skin line release the blank with minimal damage to finger. Been there a fews times.
Soaking items involving skin in warm water is the best remover from the skin. Water swells the skin and lets the ca get loose --
Pen -- back to the lathe and shear scrape followed by the abrasives.....
I mix acetone and mineral oil 50/50 use the combo to remove excess on skin, works good for me and not as harsh as straight acetone
