Will the berea razor...
I am sure that the mach 3 design is what all are.
with the exception of the double edge razor.
Bill, I beg to differ , the 2 stands from PSI that will work with Berea razors are
Item #: PKRASTB and PKRASTE but the PKRASTC will not unless you spread the holder and the chrome will chip if you do..DAMHIKT
Do you know if the stands from the Golden Nib are the same as PSI stands? I'd prefer to order from Golden Nib if possible as there are some other things I would like from there.
Hi, I find it easier to design the handles to the stands i use. I like to have the razor and brush hang level with each other, like the one i have done in the photo below. Carl
Here is a Berea razor on a PSI stand. The razor will fit if you carefully spread the ears on the holder a slight amount. I have done several with no damage to the chrome.
