Tutorial for Seam Rippers
See more from bitshird
bitshird
Adamsville, TN, USA.
Here is a basic tutorial on making a fast selling fun project that is sure to put money in your pockets and smiles on your face, they turn easy and are fun.
I hope you have loads of fun, and we have plenty more seam rippers, or you can buy them at Wal-Mart
  • Seam Ripper Tutorial.pdf
MoJo
Redmond, Washington, USA.
Thanks Ken. Great tutorial.
I've been using my Woodchuck Pen Pro for a while now and love it. Trouble is that I tried to go back to my gouge & skew and it was like I was now trying to cut with a shovel.
scotian12
Halifax, Nova Scotia, Canada.
Ken....Thank you very much for the tutorial, it will be helpful. I'm wondering if you drilled a 10 mm hole in the other end and inserted a removable plug whether this space could be used for storage for needles etc? Darrell Eisner
bitshird
Ken, thank you very much. I wonder why your head is not in any pic.s. I promise I won't send a head hunter for you.:eek::biggrin::tongue:
Very nice job my friend
Phillip, I broke one camera, which I was quite fond of, so I'm not taking any chances, besides I wanted to show something not so ugly as me..:eek::eek:
I need to see if I can get Jeff to post this in the library, I do wish I knew how to do PDF files, I'd volunteer for the librarian position.
Rangertrek
Bossier City, Louisiana, USA
Ken, very nice turorial, and excellent for your first one.
When will we see the Utube video?:biggrin:
Plan to start on a few of mine this weekend. You saved me a few steps on the learning curve.
Thanks again.
jnelson
Paducah, Ky, USA.
PDF files
The PDF files are easy to create using CutePDF. It installs and acts like a printer, and you just print to a PDF instead of a regular printer.
Best of all, the software is free.
MrWright
Passed Away Oct 12, 2022
Lockeford, California
John... I will look around and see if I have some cigar wrappers left. I use them on the small cigar shaped pens from PSI. I noticed you had wanted some on another thread. I have your address.
monophoto
Saratoga Springs, NY
I made my first seam ripper yesterday following the instructions in the tutorial. Easy project.
The one area where I found the tutorial lacking is with respect to how the blank is mounted on the lathe. The tutorial suggests using a spur center. I think I found a better way.
I mounted a short length of 1/4" all-thread in a drill chuck. Then I slipped a neoprene washer on the rod, followed by a 10mm pen bushing. Then, I slipped the blank, drilled as suggested in the tutorial, over the rod/bushing combination, and snugged everything up using the tailstock. I turned the blank down to the bushing (which was just about the perfect diameter to match the seam ripper's plastic tube.
Atlantic Beach, Florida.
Ken,
Good tutorial, just a few Questions...
on the first page, second step, you state:
"I don't own a drill press so I do mine in a f jaw chuck on a lathe, drill this hole approximately ½ inch deep."
an F jaw chuck?
You can see where I cheat and put a piece of blur painters tape a half inch in back of the flute, not the drill point the flutes
Is blur tape different from blue tape?
