What do you finish acrylic pens with?
cbb007
Glenwood, IL 60425
In another thread I mentioned that I put a ca finish on all my acrylic pens and someone asked why I put a finish on acrylic.
What do you do for acrylic pens?
ldb2000
Laurence Harbor, NJ, USA.
It's sorta like your putting a finish on a finish , resin and CA are both forms of acrylic plastic . You are doing twice the work that you have to .
I sand to about 800 and then go to the buffer and buff with tripoli (if needed) and then white diamond for a glass like finish .
ed4copies
Local Chapter Manager
Racine, WI, USA.
We put a finish on wood to protect it and make it shine.
If you want to protect your furniture, you put a piece of plexiglass over it.
What do you do to the plexiglass???
Do the same to your "plastic" pens. Remove scratches and make shiny.
OKLAHOMAN
Costa Rica
Wet sand, Brasso, Mequires plastic scratch remover, Mequires Plastic polish on most. Accourding to the material (like tru stone) will some times just wet sand and buff.BTW these are not finishes but polishes.
fernhills
Hellertown, PA, USA.
With Acrylics just wet sand and then plastic polish. With Aluminite i put a c/a finish on b/c it does not have a deep shine to it,but thats before i had a buffing set up. I will see what happens when i do another Aluminite and use the buffing system. Carl
Rifleman1776
Mountain Home, Arkansas, USA.
As you have seen, lot of techniques. Final decision is yours.
For me, I wet sand with MM or special acrylic pads to finest grade then polish with automotive scratch remover, then polish with high grade automotive caranuba wax. The wax may not be necessary but it provides that little 'extra' touch for presentation.
glycerine
Fayetteville, NC
Sand and then plastic polish. I have read that some "acrylics" are not as shiney as say PR (polyacrylic resin) and may get a better shine with CA. So if you're using CA and it's turning out how you like, then keep doing it...
Daniel
Reno, NV, USA.
I Micro Meshed to 12000 then applied Hut Crystal Coat. eventually learned that the Crystal Coat is actually a step backwards but at a polishing level that I could not see. but still a step backwards.
Recently I switched to sanding and then buffing. sure wish I had done that a long time ago. part of why I would not get out in the shop and make more pens was the thought of doing all that finishing. 15 minutes turning and 30 minutes polishing just got old fast for me. now it is 15 minutes turning and 2 minutes at the buffer. I have made about 150 pens in the last couple of months since getting my buffer. sometimes you all just need to come on over take me by the nap of the neck and stuff my head in the trough. Honestly I have to thank the members of this group that I ever even considered a buffer much less ever bought one. I recently found evidence that CA finishes will fail on at least unstabilized wood even after several years. Basically CA is getting written off as a finish for much of anything. I pulled one of the finest finished pens I have ever made out of my display cabinet the other day and found the CA had cracked on the back side of it. I never used CA on Acrylics but have always used it on wood. now I will only use it on stabilized wood if I will use it at all. I think for now I am going to the mylands finish for all my wood pens. that is until I find something wrong with it. if I do I will go to shellac. hard to beat centuries of proof that it works I guess.
RAdams
Banned
I will have to try my buffer on my PR now...
Up to reading this, I wet sanded with 600, them MM and that is usually all. Sometimes i will use Plast-X after MM, but that is rare. I like the idea of two minutes at the buffer instead of 15 minutes sanding at the lathe!
Bree
Buffalo, NY
All that I do other than sanding and buffing is to Ren wax the acrylic to keep fingerprints from showing up. It really needs nothing else.
:wink::wink::wink:
Daniel
Reno, NV, USA.
Lately I have been turning wood pens, sanding with 220 grit paper and doing a CA slurry at that point. then sanding on to 600 then buffing it as well. no actual CA finish just a wood fill. still holding my breath as to how the shine will hold up over time. A quick check the other day left me with a mixed feeling about it but the light also was not that good.
so what about the "worthless wood" pens? They are half PR and half wood...
Daniel, I have been following your testing and first must say that is the first time I read that a pen finished in CA has cracked by sitting there and on the backside. Do you attribute this to wood movement, hot or cold, sunlight, or just some other phenom??? Has this happened to anyone else??? How about a band, does it have a band around it???
Second question on this testing of the last set of pens, areyou using the pen or just letting it sit??? Using it will put it through a more rigorous test and tell you really if it will hold up. Thanks.
As far as acrylic I do as just about everyone else does and that is sand and polish. No need for another finish on top. I have to say though that over time acrylics will dull from use as will CA finished pens and then I just hit with Ren wax and buff by hand and good as new. You notice it more on clear acrylics like the computer pen. I happen to be using one as my go to pen and noticed it more so.
WildcatHollow
Boyce, Virginia, USA
I dry sand from 150 to 600, then use wet micro pads from 800 to 12000, then one to three passes with PSI plastic polish. I finish with a pass of Eagle One Wipe and Shine Auto Detailer.
t.
ELCAMINO63
mississippi
finishing acrylic
i turn to the desired basic shape then i use like an 80 grit to shape it and stop the lathe and sand lengthwise to get out the rifling and then i continue with the usual 4 to five regular sand paper grits 150 to 400 or 600 then i use a micro polish called EEE from penstate industries or wood turners catalog , then i use the micro sanding pads from 1500 to 12000 and then i use a plastic polish of your choice i work at an auto parts store so i bought some rain x headlight restore because we discontinued it and its been working awesomely .when your done its flawless
Mark
Pottstown PA
Normally I don't use CA on acrylic, but there is the occasional one that just won't mirror up. I hit it with Med CA, MM, polish (bam) - Done.
You will find that each "plastic" is different. What works for one blank won't work on the next. I'm a perfectionist. If I can find a scratch, it goes back to re-finishing. Sometimes I wander if I'm too picky. Maybe, but it's a reputation I'm trying to build. One pen at a time.
Just my $.02 - Good Luck..
delarosa
Québec, Canada
Hello, I'm not sure if this is where I ask this question but here goes !! If I want to put a decal on an acrylic blank, would the best way of covering it up for protection be the CA glue over it like a wood pen ? Thanks
Ambidex
Bristol NH 03222
not a big wet sander...seems like you put your major tool in danger..I try to do the best job on the final turn..I can go from 220..to starting fro 600...or even 1500..and I go slowly from the 1500..to the 12g..and finish with huts..hasn't let me down yet...
LeeR
Fort Collins, Colorado
Are you saying your concern is getting your lathe wet? ... And hence causing the iron ways to rust? I put a large bath towel on the lathe, to soak up any water during wet-sanding. But the MicroMesh pads are just slightly wet, and certainly not dripping wet, so the slight amount of water thrown off during sanding causes minimal dampness on the towel.
