I hate finials
Joey-Nieves
Vega Baja, Puerto Rico
Here I am making a finial pen, the kind you put on your desk, and I was almost done so I said to it;
" Khan . . . [mockingly]. . . I'm laughing at the "superior intellect." [voice dissolves into an inaudible chuckle]"
and it broke and said;
I've done far worse than kill you. I've hurt you. And I wish to go on . . . hurting you. I shall leave you as you left me. As you left her. Marooned for all eternity in the center of a dead planet . . . buried alive . . . [voice drops to a menacing whisper] . . . buried alive.
an I said:
[exploding with rage, able to stand no more] KHHHHAAAAAAAAN!!!
I hate finials
magpens
Canada
99% of kit pens made have a finial .... I don't understand the issue here ?????
mark james
IAP Collection, Curator
Medina, Ohio
Oh, but when the finial doesn't bury itself in the scraps... Almost as good as the movie (Wrath of Khan - Star Trek II). Love that movie...
Khan talking to Admiral Kirk...
Better stop while I'm behind... :wink::tongue::wink:
Oh, sorry to disagree; I love custom finials (when they fit right!).
jsolie
Sunny Murrieta, CA
It's even more frustrating when, after you've parted off that beautiful finished finial, and you find it doesn't quite fit - then while you're doing manual modifications to get it to fit, the finial decides that it needs to be on the floor somewhere never to be found again. I really don't like it when they escape at this point. :frown: :redface: :tongue:
philipff
Williamsburg, VA
If you make a NR2 MT out of a hard wood and mount a 3/8in router bearing inside a recess you cut with a drill bit, add a bit of epoxy glue to the outside surface and in a few minutes you will have a rotating bearing that will stabilize every pointed object you mount between centers, including your finials. Just be sure to use a live center to make sure the bearing is inline, and there is no glue inside the bearing. P.
Joey-Nieves
Read the original post again. The OP is making a "desk pen" or maybe a "stick pen" or a long "finial" pen and it broke in the process.
Do a good turn daily!
Don
Virgil is correct, but the thread was for blowing off steam in a humorous way. Everybody shared there individual experience and I must say that I found out that I'm not alone when it comes to dropping things or paring off small pieces. I also got some good advice, good thinggy center(although a picture wouldn't hurt) and found some fellow trekkers.
All in all a good thread
