Double Start Taps and Dies in M10 and M12
southernclay
Dawsonville, GA
Hey Ty,
Are these x.75 or x1? I may have missed. I'm pretty uninformed on taps and dies so trying to learn more. I would like to go this direction eventually.
BTW, great job keeping up with all of this!
duncsuss
Wilmington, MA
Hey Ty,
Yes indeed -- Ty's doing a great job shepherding this group of buyers :)
Looking back to the original mention of double-start taps (in the research thread), the M10 was listed as 0.75 pitch and the M12 as 0.8 pitch.
LINK to that post.
jyreene
Overseas location
Hey Ty,
LINK to that post.
Beat me to it. Thanks.
If it's not too late I'd like both sizes in dies, bottom and plug taps please.
Not too late. Added.
Here's the updated excel sheet.
  • Group Buy Official - excel version.xls
jyreene
Overseas location
Sorry to be a bother but could you please add a bottoming tap in both sizes for me. Thanks again for doing this!
Added and no bother. Just waiting on Donovan to respond regarding his order. Spread sheet is up to date otherwise.
Just a reminder that the buy closes to orders Tuesday, 19 August at 8:00 PM Eastern.
toddlajoie
Feeding Hills MA
I've been away from the forum for a bit and missed this. I'm thinking of getting in on it, but reading through the whole thread, I'm not !00% certain of the cost with the different types of taps being added and (less an issue) the numbers going up...
Originally posted:
{cut}
Here is the cost break down at the 12 pc price break:
M10 double tap
34.98
M10 double die
54.58
M12 double tap
42.90
M12 double die
51.33
M10 double set
89.56
M12 double set
94.23
{cut}
I'm interested in either one or both sizes with die and plug taps, depending on the price with the bigger discount. Sorry for being late to the party and walking in with questions...
Looks like I have until Tuesday to jump the fence, but just in case I misunderstood that and the doors are closing early, put me in for:
M10 Die
M10 Plug Tap
Depending on the above information, and having time to adjust, I may add the M12 in.
jyreene
Overseas location
Originally posted:
{cut}
M10 double tap
34.98
M10 double die
54.58
M12 double tap
42.90
M12 double die
51.33
M10 double set
89.56
M12 double set
94.23
{cut}
M10 Die
M10 Plug Tap
Here is the current break down:
We have more than 12 per size of die but that is the last price break for dies:
[FONT=&quot]M10-75 Double Lead HS 1"OD for $49.00 plus $67.00 tooling charge (split across all the current buyers).
[/FONT]
[FONT=&quot][FONT=&quot]M12-.8 Double Lead HS 1"OD for $45.50 plus $70 tooling charge (split across all current buyers).
Taps keeps going. We are currently at 48 plus for each:
[/FONT]
[/FONT]
[FONT=&quot]M10-.75 double lead
[/FONT]
[FONT=&quot]48 pc 26.55ea[/FONT]
[FONT=&quot]72pc 24.20ea[/FONT]
[FONT=&quot][/FONT]
[FONT=&quot]M12-.8 double lead[/FONT]
[FONT=&quot]48 pc 33.55ea[/FONT]
[FONT=&quot]72pc 31.70ea
So if you wanted just a set of M10 (one tap only) you would be paying roughly:
One tap: $77.18
Two taps: $103.73
Three taps: $130.28
M12:
One tap: $80.94
Two taps: $114.49
Three taps: $148.04
I've updated the spread sheet to do some rough calculations of price for each person I add. The only real change will come at the next price break (72 taps each size) and a few cents each new person that signs up because of the tooling breakdown.
[/FONT]
wyone
this is such a HUGE deal.. but I am really new at this. and have not turned a single fountain pen yet, but hope to in the future. I just have no idea what would be a good starter set for me. The discount is huge compared to the retail price and I would hate to miss out. Any suggestions? Also... isn't a tap needed for the nib? as you can tell.. TOTAL Newby. but LOVE pens now. I will be posting pics in the near future. I have come a long way in a few weeks, a LOT in due to this organization. If I am not at work, or turning, or sleeping, I am reading forums. lol
jyreene
Overseas location
They aren't just for fountain pens. I prefer rollerball anyways. I just need to learn how to make my own metal nose cones. Though I've seen many great ones from the material.
If you want to jump into this you would need more than just the taps and dies. You would need a way to hold the die and a drill chuck. A tap is also needed for the nib unless you go antique style and press and glue it in. These are generally for cap to body but can be used for more.
I would take a look at the library. There's a good tutorial on kitless that will help you know the wonderful rabbit hole this leads to.
jyreene
Overseas location
Okay updated. If we get 72 taps for each it's almost like getting a free tap if you are already buying two. No pressure just did some number crunching.
edstreet
No longer confused....
Since I was the one who pointed this out to you I figured I would go first.
Put me down for all 3 taps in both M10 and M12.
That is:
M10 taper tap, plug tap, bottom tap, die.
M12 taper tap, plug tap, bottom tap, die.
My cost change would be + $17.50 fyi :)
Dan Masshardt
Mechanicsburg, PA
Ty - if it helps us get there, I'll add another tap to my order.
For 12mm, switch from plug only to taper and bottoming.
If it doesn't help...
jyreene
Overseas location
Updated. We are now 1 shy on the M10s and 9 shy on the M12s.
Dan if we don't make it on the M12 just remind me after the close (I'll post a quick this is what I have while calculating the shipping and what not) and I'll put you back to just the plug.
Karl_99
Winfield, PA
I would like to jump in on this and order:
M12 die with plug and bottoming taps
M10 die with plug and bottoming taps
Thank you, Karl
stever521
Colorado
add m10 and m12 second/plug taps
Hi,
I would like to add to my original order one each M10 and M12 second/plug tap please.
This should cover any and all uses.
Thanks,
Steve.
RDH79
Rimersburg, Pa, USA.
Ok Jump my order to all one of everything
That would be
Thank You!!
Rich
duncsuss
Wilmington, MA
If it takes us over the 72 threshhold, add a bottoming tap in both M10 and M12 to my order (which is second/plug tap plus die in each size).
If we don't hit the 72 threshhold, I'll stick with just the second/plug tap and die in each size.
Thanks!
wizard
Houston, Texas
Ty,
If it helps to get to the number/quantity you need , go ahead and add a taper tap to each of my sets of M10 and M12 die, plug and bottoming taps that I have currently ordered. So it would be:
M10 taper tap, plug tap, bottoming tap, die.
M12 taper tap, plug tap, bottoming tap, die.
Doc:)
