Ebonite and casein
beck3906
Belton, TX 76513
I know it's been discussed a number of times but thought I would skip the research and just ask. :rolleyes:
I'm making my first pens with black ebonite and casein. What finish do i use on these materials?
PenMan1
Eatonton, Georgia
No finish at all Rick. Casein is a natural "breathing" entity. A coating, such as CA, Turner's Wood Finish, Shellac (ie shellawax, EEE) and even wax will cause the casein to crack. Some people use Ren Wax or Kiwi natural shoe polish over casein but I don't dare do this. Additionally, a pen mill should NEVER touch casein. Square ends with tubes with a sanding jig. I dip the casein blank in water to keep it cool when squaring ends. Additionally, I turn casein at high speed, with carbide cutters lubricated with Brasso. The carbide and high speed leaves a finish fine enough to start the sanding process at 600 or 1500 grit.
Then Micromesh to a shine.
I handle ebonite much the same way, (NEVER GET IT HOT) except I do use Novus 1, Novus 2, and finally McGuires PlastX after Micromesh "pad 9".
Slow is NOT the idea with either materials, but heat ruins either ebonite or casein. I ALWAYS keep the blank and tool cool as I turn.
OKLAHOMAN
Costa Rica
I agree withy Andy, I use the 2x2 soft touch MM pads and spray the pads with water as I use them keeping the blank and pads wet. You can use the sheets it's just the pads remain wet longer and keep the blanks cool.
beck3906
Belton, TX 76513
This may be a learning experience... Costly at that.
Drilled the upper bodies yesterday and felt the ebonite as warm. May finish it to see how it comes out. I can always take it apart and do another body. :redface:
Thanks to both of you for the info.
OKLAHOMAN
Costa Rica
A little "WARM" is ok just don't get it hot. I have even buffed them "LIGHTLY" om my 1750 RPM buffer with tripoli and white diamond just don't get it hot.
